Will a set of 275/50/16 drag radials on 15x7 Firebird rims fit? need answer fast!
Old May 12, 2001 | 09:53 AM
BrianB's Avatar
I am planning on buying the BF Goodrich Drag Radials in the size 275/50/15, and putting them on a pair of standard Firebird rims 15x7 I believe. I was curious if these tires will be too wide and possibly rub anything on the rear? BTW: Going on an 1988 GTA
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
[This message has been edited by BrianB (edited May 12, 2001).]
Old May 12, 2001 | 09:57 AM
snakeskinner's Avatar
they will fit on the rims, although not optimally, but I don't know about rubbing.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old May 12, 2001 | 02:06 PM
AfootVoyager's Avatar
they will fit...however they may rub at the top of the fenders during conering or harsh bumps...if you want to run this size tire all of the time then you might want to consider finding a way to raise the rear of your car by about an inch...i ran 275/60's (not drag radials tho) on the rear of my T/A for a couple of months and they rode very well except for the driver side tire rubbing occasionally...you might want to also consider going to something like a 255/60...that is what i have now and there are no interference problems at all
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old May 12, 2001 | 04:13 PM
BrianB's Avatar
These will just be used to drive to the track, race, and back home. That is all the use they will get. I just wanna make positive that they will not rub.
Old May 12, 2001 | 04:33 PM
82camaro's Avatar
Car: 82 camaro SC
Depends on your suspension mods if they will rub or not. The 275/50 is going to be too wide for a 7 inch wheel, especially for maximum traction.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 12, 2001 | 05:56 PM
87 IROC 350 TPI's Avatar
the tire's will have no problem's on the car, but a 16" tire, is not going to fit a 15" wheel
Old May 12, 2001 | 09:53 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
As said above, a 16" tire won't fit on a 15" rim. BFG makes a DR size of 275/50/15 and 275/60/15 which will fit your rims. These tires are recommended for rims 7-11 inches wide. The 60 series tire has a 28" diameter and will/may rub on extreme bumps (had 28" ET streets that did that). The 50 series diameter is 26.1 (same as stock 245/50/16 tires that came on 3rd gens) so they shouldn't rub at all.
Sparks a flyin'
PS - I'm thinking about running the 50 series on some 15x7 Weld Prostars I have.
colton_carlson
Mar 8, 2019 12:21 PM
Fast355
Dec 2, 2016 06:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
fcorallo
Aug 20, 2015 11:28 PM
