Troubles siphoning fuel from 84 Z28 HO.
Old Sep 18, 2004 | 10:16 PM
Ih8myZ28's Avatar
Car: 1984 Camaro Z28 HO
Engine: L69
I have about 1/4 tank of gasoline in my 84 Z28 that has been sitting for roughly 1 year. Not expecting it to sit that long, I neglected to add any stabilizer prior to parking it.
I have a 6' siphon hose that I have been trying to get the old fuel out with, but have not been having much luck. I can get the hose down there quite far, but it can't find its way into the actual gasoline.
I know some 3rd gen's had baffled tanks (namely 1LE's). Is there a chance L69's did as well and the hose is just scooting along atop the baffling, never finding the gas sitting below? If not, any tips to getting the hose to find where the gas is hiding?
Failing the siphoning idea, what's next? I've read many posts about unplugging the fuel filter and running the fuel pump by turning the key, but aren't 84 Z28's mechanical pumps? Can I do a similar trick with this pump to get the gasoline out?
What other options do I have? Would I be safe just topping up the tank with fresh gas at this point?
Thanks in advance.
Old Sep 19, 2004 | 12:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's only a year and it's only a quarter of a tank I wouldn't worry about it too much.
Old Sep 19, 2004 | 12:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You could probably get away with topping it off if you're worried about it.
Old Sep 20, 2004 | 01:47 AM
Ih8myZ28's Avatar
Engine: L69
Yeah, that's what I ended up doing. I added about 5 galons of fresh gas and started it up. Doesn't run too bad. I tried to get the siphon in there again once it was up to a half tank just for curiousity sake, but still no luck. Wonder what's up with that...
Frozer!!!
Jan 19, 2024 04:55 PM
bryan623
Mar 22, 2021 06:43 PM
EFR2000
Aug 18, 2015 08:54 PM
