car smoking
Old Sep 19, 2004 | 01:15 PM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
car smoking
i just got a rebuilt 350 (carbed) put in swapped from a 305 (carbed) and well when i start it up it smokes quite a bit, i keep on asking the installer and he keeps on coming back its my carb because its running too lean. its a stock qjet from the 305. also during heavy accel it starts to smoke. i also heard something about seals somewhere i can't remember tho if you have the same prob of know what i could do to fix it or what not please help me out.
thanks
Old Sep 19, 2004 | 05:32 PM
curtis84ta's Avatar
anyone have any ideas on what it could be or isn't?
Old Sep 19, 2004 | 05:51 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
what color is the smoke. blue. white. black. blue that means oils getting into the combustion chamber via. valve guieds are worn. or bad piston rings. but this soudns liek ti's your carb it's running ethier lean or rich. get it tuned
Old Sep 19, 2004 | 06:59 PM
curtis84ta's Avatar
black on accel white on startup
Old Sep 19, 2004 | 07:01 PM
curtis84ta's Avatar
anyone know how to post a video ? if so i can show ya what it does.
Old Sep 19, 2004 | 07:29 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Ok, stop taking it to this guy. For starters, Black smoke indicates a RICH condition, and the white smoke indicates coolant being burned. I have also seen white smoke on startup from carburated cars running too rich. Get that carburetor rebuilt, and adjusted properly. Until you can do so, check the choke to make sure it's operating correctly. Linkage and all. Good luck!
Old Sep 19, 2004 | 10:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Are you sure the startup smoke isn't a light bluish color?
Old Sep 20, 2004 | 06:37 AM
curtis84ta's Avatar
im now positive its (edit) white. i took it for a spintoday its white which means its lean. um by the way its mechanical
Old Sep 20, 2004 | 09:30 AM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
lol. well then. your running rich. check your choke it could be stuck. or something with the carb isnt' working right. myn runs rich because it defulted to that setting. do to i broke some computer thing. make sure all the connections are hooked up. this is a q-jet carb right. computer controlled?? a lil more info would be nice thanks
Old Sep 20, 2004 | 01:07 PM
curtis84ta's Avatar
smoke is white i took a look yesterday but it was in the shade and looked black, but now driving it on the street today i looked in my rear and white smoked was pouring out. and its a mechanical qjet rochester
Old Sep 20, 2004 | 02:32 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
so white. make you mind up. like was it alot of white cause if it is you ethier have. a warped head. if it's alluminum. bad head gasket. so stop drivng it do not hydro lock your engien. you bruning coolent and it's really bad. get ti fixed
Old Sep 20, 2004 | 02:40 PM
sellmanb's Avatar
Car: '86 Berlinetta
yeah, you've either got a bad head gasket or a warped head... I too would suggest against driving it too much... I would suggest changing your oil though and seeing if you made a milkshake though....
if you have another car to drive around, do it until you can take off your heads and determine the real problem. You'll be able to tell if it's the head gasket pretty quickly (and since you're taking the heads offf anyways you'll need to replace the gasket), to check if the heads are warped, just put it on the ground and look for gaps I guess.
Old Sep 21, 2004 | 12:20 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
If it's smoking white on startup, i'd think it's just condensation burning off in the exhaust. Any water in the oil, or vice-versa?
If it remains white after it's fully warmed up, then there must be a more serious problem. But I think more info is needed...
Blue smoke = oil
White = water
Black = fuel
I know that much at least.
Old Sep 22, 2004 | 11:15 AM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
hey curtis, is the vacuum tubing removed from your exhuast system?
bryan623
Mar 22, 2021 06:43 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
