oops
Old Sep 20, 2004 | 01:46 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
oops
anyone ever do anything this stupid.... well i put my flexplate (flywheel) in backwards on an 85 iroc does it matter?
Old Sep 20, 2004 | 01:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it matters. Alot.
Move the trans back an inch or 2, and turn it around right.
Old Sep 20, 2004 | 02:11 PM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
i heard from ase master mechanic that it wont matter as long as the the teeth mesh with the starter but it didnt sound right to me do you know why it would matter if it is backwards?
Old Sep 20, 2004 | 02:32 PM
sellmanb's Avatar
Car: '86 Berlinetta
with something as crucial as the flywheel, or flexplate, whichever you've got... why would you want to try to jerry-rig it? lol.
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
does the guy that told me that even know what he is talking about
Old Sep 20, 2004 | 02:36 PM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
i defientely dont wanna mess it up but its still alot of work taking the trans back off just wondering if anyone was ever dumb as me b4
Old Sep 20, 2004 | 02:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It matters, because the crank flange and the surface that the converter bolts to, aren't in the same plane; and the raised "pads" on the flex plate for the converter bolts, are usually too small for the "pads" on the converter to fit into the back side of; and the crank flange usually isn't flat on the side toward the bolts, so you've got that part of the flex plate all bent up because it won't sit flat up against the crank.
I know you don't want to take it back apart, and I sympathize; but that isn't going to make your car work correctly in spite of the reality. The same goes for in case somebody pipes up and tells you what you want to hear. Just because you want to hear it and somebody says it, doesn't make it so. You need to put it together right.
And yes, although I can't answer about the "dumb" part, it's been done before, once or maybe even twice.
Old Sep 20, 2004 | 09:28 PM
sockfootball22's Avatar
Car: 84 z28
what kind of sound would it make if u had the flywheel on backwords? would it make u go through a few starters and make it sound like something is grinding?
Old Sep 21, 2004 | 05:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The starter would probably work. The problems would more likely involve transmitting engine power.
german-motorsport
Jun 24, 2002 09:55 PM
