Ecm not working?
Old Sep 23, 2004 | 05:45 PM
atopjian's Avatar
Car: 88 iroc
Transmission: auto
Ecm not working?
Im finsishing up installing a new motor in my car and I am having a few problems. The car wont start. starter turns motor, theres spark and fuel preasure. Pulled a spark plug to see if there was any gas on it nothing. I sprayed some starting fluid into the plenum and the engine sputtered a little then stopped. Had a friend that has put a distributor in a few times come over and install the distrubtor. Tried jumping the pins for the computer to see what would happen and it didnt flash back anything, so im thinking its computer related. where would the ground wires in the engine bay be located? Also pulled off one of the injector plugs and put a multimeter to it and got nothing there. How do I tell if the ecm isnt grounded or is just bad? Any help would be great. This thing is driving me cazy.
Old Sep 23, 2004 | 08:42 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
My car is an 87 and the ECM/ESC ground wire is on the back of the lft cylinder head under the wiring harness. They are 2 tan wires in a crimped on ring terminal mounted to a stud/nut arrangement.
I just fought a problem with my car for over 2 weeks, and found that the crimped terminal had corroded on these wires. Car would jump, buck, tach jump, not start sometimes, but would run good in limp home mode with ESC wire disconnected. I cut the old ring terminal off, cripmed/soldered a new one one and all my problems went away.
Old Sep 26, 2004 | 03:42 PM
atopjian's Avatar
Car: 88 iroc
Transmission: auto
What does esc stand for?
Old Sep 26, 2004 | 05:37 PM
Morley's Avatar
ESC= Electronic Spark Control
No pulse from the dist. to the ECM will prevent the injectors from firing...so will blown/missing injector fuses.
specialized
Jun 18, 2022 09:26 AM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
