Towing a thirdgen?????
Old Sep 24, 2004 | 11:57 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
ok i'm moving to st. louis next week, and i need to know the proper way to tow my car with a dolley from like u-haul. I cant leave it in park, i dont know about leaving it in neutral, what will happen. My dad said i will need to drop the driveshaft but who actually does that?
Shane
Old Sep 25, 2004 | 12:04 AM
rjmcgee's Avatar
You have to drop the driveline to go more than around 50 miles from what I have heard. Or rent a car trailer from U haul.
Old Sep 25, 2004 | 12:42 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
play it safe and drop the driveshaft.
Old Sep 25, 2004 | 12:48 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah thats what i would do just drop it and not worry about anything ....
Old Sep 25, 2004 | 01:12 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
this may be a little dangerous, but couldn't u put the rear on the trailer and leave the front wheels on the ground?? with the power off the wheels locks and can't be turned, right?? in my owners manual it says to turn the wheel all the way to one side so no one can tow it from behind, i mean i really doubt u could do that but it's a thought
Old Sep 25, 2004 | 01:54 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
just take out the drive shaft, its only 4 bolts.
Old Sep 25, 2004 | 10:08 AM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Just Tow It Backwards....
Kind of scary when it wiggles, but I towed my IROC from NJ to Pittsburgh on a tow dolly, with the rear wheels on the dolly. Just don't be pulling your car with something that weighs less than your thirdgen. If you decide to remove the driveshaft, remember to seal the end of the tranny where the drive shaft goes in or you will lose your tranny fluid.
There is a thread on here somewhere with a whole big debate on the subject.
Old Sep 25, 2004 | 01:12 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i don't see what the whole debate would be about.
remove 4 bolts, remove driveshaft, tape caps on u-joint so they won't fall off, and cover the end of the tail shaft so your tranny fluid doesn't poor out.
Then you can correctly and safely tow your car.
it is seriously about 10 mins of work. and that includes the time to go find the nessicary tools, and to go find your jack and jack stands.
Old Sep 25, 2004 | 05:46 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
why not just drive it? im guessign your moving with your parents so you wouldnt be needed to drive
Old Sep 25, 2004 | 06:46 PM
ljnowell's Avatar
In order for him to get to st louis, he must go past, or through my town. PLEASE dont tell him to drive, I have a child!
Old Sep 25, 2004 | 07:07 PM
THEGENERAL's Avatar
LOL ....i agree totally wait till he gets to st.louis to cut him loose behind the wheel........LOL
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Ozz1967
Aug 16, 2015 10:23 PM
