Final word on a/c and smog removal...
Old Sep 27, 2004 | 06:40 PM
Cra-Z-Canuck's Avatar
Car: 88 IROC Convertible
Engine: 355 (Finally!)
Transmission: Auto :(
Ok, after numerous searches I've read many opinions and methods for removing both ac and smog.
The one I want to do is this one (cheapest!)
Has anyone run this setup? Does it work? And what size belt?
Yes, I know 1LE delete pulley is simple, but GMPartsDirect won't ship to Canada and dealers want $125 for it!!!
Old Sep 28, 2004 | 02:58 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=251855
looks just like what the one guy is running maybe a different routing but does what u need to do.
https://www.thirdgen.org/techbb2/att...postid=1992796
Old Sep 28, 2004 | 09:38 AM
That routing is slightly different - I wonder how much contact is being made with the power steering pump pulley in that one - does anyone else have experience with this or know the lengths with either of these routings?
Old Sep 28, 2004 | 10:25 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
the problem with taking a pulley away from the system where the AC would be is that now the idler/tensioner is running on the wrong side of the belt. The grooves of the serpentine belt would be running on a smooth pulley. Not too sure if this is ok to do but if you could somehow get a grooved pulley to put on the tensioner arm you are good to go.
Old Sep 28, 2004 | 12:00 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You'd have to flip the tensionor upside down so that it pushes up and out and not down.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
