TECH assistance need!!!!!!!!!!!!
Old May 15, 2001 | 10:54 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
It is an 89 2.8 RS
Guys, I really need an answer to this. My car needed a new ignition module because it had no spark, I did that and now theres spark, but while the car wasn't running I changed the distributor cap and rotor, but I'm not sure if I put all the wires in the right place.
So I changed the distributor cap and rotor, put the new ignition module in and it started, it idled rough and when I put it into reverse and pushed the peddle it got more rough and sounded like it was going to stall, so I shut it off and figured I put the wires on incorrectly from this reaction, so I moved some around to where I thought I might have made a mistake and then it wouldn't start. I didn't know where the wires should have went since I rearanged them some, so I did a search on the V6 board telling u where the wires should go and something about the rotor having to line up and harmonic balancer BS. I put them where they said to and it still won't start. Some1 has to know, I need this car to start, thanks guys!!
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited May 15, 2001).]
Old May 15, 2001 | 11:21 PM
Administrator
Come on techs, Vader, GMTech, any1!!
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 01:19 AM
Administrator
BTTT
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 01:26 AM
Guest
Guest
Posts: n/a
Im not into V6's so...
You need to know the firing order, and how that is arranged on the cap. Make sure the wires are on right, thats step 1.
Step 2 is to make sure your timing is set right, it could very well be off even though you didnt change it (at least I am assuming you didnt).
Old May 16, 2001 | 01:28 AM
Administrator
I've already did that stuff and I didn't adjust the timing, read my post on the V6 board also.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 01:37 AM
Guest
Guest
Posts: n/a
Well try adjusting the timing, it might be off.
Old May 16, 2001 | 01:38 AM
Administrator
How could the timing just go and adjust itself?? It started and now it won't, when I crank for a while there is a sound and a line comes right off of the plenum.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 03:02 AM
coach's Avatar
If you didn't move the distributor, I don't think that the timing is off. I'll give you some suggestions. Some of the stuff you've probably already have done, so please don't think I'm trying to insult your inteligence.
If you've got a repair manual, such as Haynes, the firing order and the numbered cylinders are shown. The V6 is different from the V8 in that the number 1 cylinder is the very-front cylinder on the passenger side. So, cylinders 1,3,5 are on the passenger side. Cylinders 2,4,6 are on the drivers side (2 being the front cylinder).
The firing order for the V6 is 1-2-3-4-5-6.
The rotor in the distributor moves clockwise. I don't have a scanner, so I'll try to draw the distributor wire terminal.
3 4
Distributor: 2 5
1 6
front
cylinders: 5 6
3 4
1 2
front of engine
Now, If you(or anyone) have moved the distributor, then the illustration above will be a little different than what your distributor looks like.
If everything checks out, here are some other possibilities that could be the problem.
1. Look inside each plug wire boot to see if the metal connectors are still attached to the wire. They can tear apart inside the boot, and you may not realize it. You can check with a small screw driver(with the ignition off. I know. Duh!!!)
2. Make sure the plug wires snap securely on the distributor terminal and spark plug. If ones a little loose on the plug, it may not fire.
That's about all I can think of right now. Hope I have been of some help.
Old May 16, 2001 | 03:13 AM
coach's Avatar
The number illustrations didn't show up right (the way I typed them in),it pulled everything to the left of the screen. So I'll try another way.
This illustration should be round(like the distributor).
Distributor:
---3-4
--2---5
---1-6
front
(the dashes don't mean anything).
Cylinders:
5---6
3---4
1---2
front of engine.
Let's hope this comes out right.
Old May 16, 2001 | 03:46 AM
Administrator
Thanks, kick a**!!
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited May 16, 2001).]
Old May 16, 2001 | 04:57 AM
Administrator
It worked, they were mixed up, thanks!!
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 05:47 AM
coach's Avatar
I put some other tips here, before I knew you fixed it. I'm trying to edit this post, but it won't let me.
[This message has been edited by coach (edited May 16, 2001).]
Old May 16, 2001 | 06:00 AM
coach's Avatar
I just saw your message, that you got her started. I guess you can disregard my last post. I'm glad everything worked out for you. There's nothing quite like the feeling of when the car finally fires up after a lot of headaches, right?
I'd put a smillie face here but I don't know how to post it. haha
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
