I still need help installing my new gauge cluster!
Old May 14, 2001 | 08:08 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Okay, I traced all of the 'pins' on the back of my new cluster from an 87 GTA, and then I traced them all on my spare 83 cluster, and not one is the same. cluster will bolt right in, but nothing will finction correctly. Is it possible to replace the gauge cluster wiring harness? I don't really want to re-wire my harness, but I will if I have to. Someone has to have had their dash apart before...
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old May 15, 2001 | 05:38 AM
Boomer's Avatar
Ward - this is very interesting.
I have an '84. I swapped for an '85 cluster, changed two sensors and everything is fine.
From the cars/clusters I looked at, sometime in the very late 80's / early 90's, a change to the instrument layout was made - that is why I elected to stay with a cluster that was as close to my model year as possible. The printed circuitry on an '83 verses an '87 may very well be different.
Does the circuit board layout look the same on both clusters? If, not, someone with extensive experience in clusters is going to have to help you.
I think the physical gauge lay out (3 small between two large) is the same for '83 / '87 - right? Seems like it should work. Does NOTHING work? The tach? Fuel gauge?
I am not much help - hopefully, someone else will chime in here.
Boomer
Old May 15, 2001 | 04:03 PM
camarocowboy's Avatar
Your 83 will not work w/ the 87,I did the same w/ my 87 z28 and I had to have a cluster for 86-87 only and I don't know why but when I put the 86 in,it worked fine.
Old May 16, 2001 | 07:45 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Ward is talking about a Firebird dash, not a Camaro one....they're a bit different.
I could help if I had a Haynes Firebird manual with the electrical diagrams, but unfortunately, my Chilton's doesn't have detailed enough diagrams.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
206+k mile LG4/5-speed
14.935@94.14
Old May 16, 2001 | 11:12 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I need to know if i can take the cluster wiring harness from a firebird with an electronic speedo. in 87 (i think, maybe 86) they were changed to electronic, and they changed the whole interior and gauge cluster, including the wiring for it.
1983 Firebird
TH700R4 Auto
Small Block 400
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
