HELP!! Pully on Alternator loose
Old Oct 2, 2004 | 11:50 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
The pully & fan has come loose on my car.. How the heck do you tighten it back on? it has a nut and what appears to be either Torqux or an allen socket on the shaft. Any idea what size the center is?
Old Oct 2, 2004 | 11:53 AM
ljnowell's Avatar
Dont worry about the center of the shaft, put a socket on the nut and give her a crank. I've changed countless pulleys this way.
Old Oct 2, 2004 | 11:55 AM
Car: 89 Camaro RS
Engine: 305 TBI
Tried that.. all it does is turn the shaft.. how do you stop the shaft from turning, in order to tighten the nut. Both the fan and pulley spin freely.. I thought there would be some teeth or something to grip the pulley.
Old Oct 2, 2004 | 12:07 PM
ljnowell's Avatar
I've always been able to clamp some vice grips on a fan blade, and turn the nut with a socket. Worked the last 100 times I did it.
Old Oct 2, 2004 | 12:18 PM
Car: 89 Camaro RS
Engine: 305 TBI
well closer inspection revieled either a damaged spacer on the shaft or damaged pulley center. it whobbles up and down on the shaft. 'toast'. so I'll need to pull it out and replace the pulley and or alternator.. on thing is at least.. I'm pulling it off the road for the winter.. granted I could drive it for much longer becuase it'll be a while till snow arrives.. but oh well.
Well thanks for the quick help on the matter anyways.
Old Oct 2, 2004 | 06:47 PM
ljnowell's Avatar
Hmm, sounds a little different. Wish I could have helped you a little more.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
