thermostat bolt stripped
i need to change my 160 stat to a 180 cuz my car runs too cold(i put in the 160 to try to fix the cooling problem it used to have
, but now with the griffin radiator it runs really cold)
however, when i put the 160 in, one of the housing bolts was definitely stripped(where the bolt goes into is stripped, not the bolt itself, previous owner was a hacker). i managed to tighten it a few turns, and luckily it doesnt leak. however, i dont think ill be that lucky again. how can i get around this?
i was thinking i could just drill a larger hole, tap it, and put a new larger bolt in, but metal shavings would fall down into the coolant wouldnt they? this would be bad right?
any help/ideas are appreciated
, but now with the griffin radiator it runs really cold)however, when i put the 160 in, one of the housing bolts was definitely stripped(where the bolt goes into is stripped, not the bolt itself, previous owner was a hacker). i managed to tighten it a few turns, and luckily it doesnt leak. however, i dont think ill be that lucky again. how can i get around this?
Car: 4
Engine: 6
Transmission: 5
DON'T drill and tap to a larger size. You'll be sorry, sooner or later.
Drilling and tapping to the original size won't do anything. "Stripped" means the metal that the threads would be tapped out of, is now missing. There's nothing there to tap. There will be even less metal if you drill it.
The Heli-coil method is the way to go.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah and if you drill to a different size your also going to be drilling out the water neck too.....
go to a parts store tell them you need a heli coil and tell them what you are doing they will set you up
Car: 1990 Firebird
Engine: LS3
another vote for heli coil
I heli coiled both of the bolts for the themostat housing and they haven't leaked a drop. and to keep metal shavings out of the coolant...good old fashion duct tape.
You may have to drill out the thermostat housing too, maybe. The last time I had to do this, I didnt. Also, you will have two different sizes of bolts, which can be confusing to some, I guess. Its really all personal preference.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
