someone has to know... 325 hp and 375 ft/lbs???
Old Mar 21, 2001 | 07:56 PM
camaro6spd's Avatar
I want 325 hp and 375ft/lbs, what kind of TPI engine would be best suited for this. I will have a 3" Cat-back, hooker headers, cam, port and gasket-match the induction system, air foil and other minor stuff. What do you guys suggest I do? Which cam would be good for this, what other mods or what needs to be changed to get this. I will be upgrading from a 305 so I am looking for a 350 or 383. What about fastburn heads and what a Torquer II's like?
basically I am just looking for setups around this output or maybe more. The drive-train will be taken care of with a T-56. I am open for idea's except for, NO2, super or turbo charging and I want it to be TPI. Maybe it will be hard to do, I don't know, I am new to this. What are you guys running and what kind of output are you getting with that setup?
Old Mar 21, 2001 | 08:38 PM
matty350TPI's Avatar
Hey I am currently running 300hp and 370ft. lbs of torque out of a GM crate motor. It was straight out of the box and goes like crazy. If you want let me know and I will find you the exact engine code.
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Mar 21, 2001 | 08:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My previous engine, with a ZZ4 cam, ported Corvette L98 heads, ported stock TPI intake, and SLP 1 5/8" headers put 280 HP and 380 TQ at the rear wheels on a dyno. If you do the math thats about 325 HP and 430 TQ at the flywheel. Sound good?
Im expecting my new engine to make over 300 HP at the wheels, and who knows on the torque. It just better run 12's!
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 21, 2001 | 09:12 PM
camaro6spd's Avatar
matty350TPI:
Where did you get it? I would love to know the numbers on that. Thanks
Kevin91Z:
I saw you car and love it. The ZZ4 cam works with FI? I thought the ZZ4 was carbed. How much did it cost you to build?
[This message has been edited by camaro6spd (edited March 21, 2001).]
Old Mar 21, 2001 | 09:32 PM
camaro6spd's Avatar
Who runs a supercharger and how much hp and ft/lbs do you now have?? Just curious.
-Tom
Old Mar 22, 2001 | 02:37 PM
camaro6spd's Avatar
What eles are you guys getting out there with the 350, 383 and 400 small blocks, what did it cost you build power?
-Tom
Old May 16, 2001 | 05:47 PM
camaro6spd's Avatar
matty, did you ever gets those numbers, how about the place you bought is and the price.
Old May 16, 2001 | 09:13 PM
Kevin91Z's Avatar
My new engine made 317 HP and 418 TQ to the wheels.
For price I couldnt tell you, I got a lot of my parts used and my dad and I did the labor, as he is a mechanic. I'm still searching for 12's...
Old May 16, 2001 | 11:05 PM
Slow Iroc's Avatar
Peak numbers don't mean as much as where they occur.
Example, L98 - LS1, both make similar peak torque, but due to the head, and overall motor materials of the LS1 it creates that same peak at an additional 1400-1600 RPM higher, and they are how much faster than our cars?
Just thought you might want to keep that in mind when building your engine, not that I know how to build or modify one for racing, lol.
Old May 17, 2001 | 01:55 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Slow Iroc - You gotta be 16 years old.......17 tops.
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old May 17, 2001 | 04:08 AM
Slow Iroc's Avatar
Okay, so first, I don't know of anyone running 8's with a 200, then I'm 16 or 17?
26 Thanks... just out of curiosity, why is it that you fully beleive I'm full of crap no matter how much theory, fact, or evidence I back what I say up with?
Old May 17, 2001 | 10:02 AM
camaro6spd's Avatar
Don't turn this post into a flame war!
Old May 17, 2001 | 01:53 PM
KW87GTA's Avatar
It really shoudln't be too hard for you to get 325 at the crank. In fact, you should be able to do it with the stock TPI, injectors, heads, and the cam too, although a cam could be a nice increase. Good luck.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
1992rs/ss
16
Jan 28, 2016 09:58 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
the_hamturdler
Sep 30, 2015 12:50 PM
luvofjah
Aug 29, 2015 08:33 PM
