400 horse
Old Oct 5, 2004 | 12:21 PM
diablo0072k's Avatar
400 horse
i wanna build about 400-450 horse out of a 327 for my 86 z. id like to know about what its gonna take. any help would be great
Old Oct 5, 2004 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
2 ways:
1. Nitrous
2. Heads with great flow, high compression, 7500 RPM
HP = torque x RPM / 5252
Torque is a function of 3 things: cubic inches (you have only 327), "thermal efficiency" which is mostly a function of compression, and cylinder fill which will never be 100% except for possibly in a very narrow band around some "tuned" point in the induction system. You'll be lucky to get much more than 400 ft-lbs of torque out of it at any RPM; and you'll need to have 400 ft-lbs of torque at about 6000 RPM to get 450 HP out of it.
It's alot easier with more inches.
Old Oct 5, 2004 | 03:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
AFR 210 aluminum heads, Holley Dominator single plane intake, Holley 830 CFM DP carb, Crane 280/288 PowerMax solid cam, ~10.5:1 compression, 1-3/4" headers, and two Dynomax Ultra Flow 3" mufflers should do it.
Oh. And a 3,500+ stall converter (if auto trans) and 4.10 + gears.
EA 3.0 says ~460 HP.
Old Oct 5, 2004 | 06:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by RB83L69
1. Nitrous
3. Blower
Old Oct 5, 2004 | 07:54 PM
sellmanb's Avatar
Car: '86 Berlinetta
Welcome to the boards.
Dont let these naysayers get you down. They're simply trying to say that it would be easier with a 350, and more cost effective (proven, not monkey-spank)... but it's basically in the fuel delivery and heads, if you can figure out how to stroke your engine, I'm sure you'd have no problem figuring out the $'s to get your motor to 450hp
Old Oct 5, 2004 | 09:54 PM
rangelec's Avatar
lightly ported vortecs and a good cam should make 400 hp easily-stock vortecs should probably do it with the right cam.
Old Oct 5, 2004 | 11:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 400 horse
1st, Welcome Aboard.
Okay, what is it going to take? I'd figure on about $5000. Not only do you have to make it, you have to keep it together.
Or, for about the same money, http://www.sdpc2000.com/cart.asp?act...120&pid=156334
Old Oct 6, 2004 | 12:06 AM
damn. id love the GMPP 383, but i dont have 5 grand right now. what if id rebuild the 327 with around 10.5-11:1 compression, hillbilly ported 2.02 camle back heads, good cam (dont know how big yet, need a little help) performer RPM airgap intake, and headers around what would i be looking at.
Old Oct 6, 2004 | 02:34 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
If you really want to make horsepower....spend some extra money on some good aftermarket heads ( Aluminium best IMHO ).
Head technology is so far ahead of the double bumps it just doesn't make sense to even bother with modifying them. You're dealing with 30+ year old technology. In the end you'll spend almost as much money as buying new, reconditioning, porting, new guides, valves, springs etc....and you'll still have a set of 30+ year old heads.
Old Oct 6, 2004 | 07:56 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
close
Old Oct 6, 2004 | 01:43 PM
camaro_doc's Avatar
where could i find that dyno program you guys are using? Any help would be apreciated.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
