starter sucks
Old May 17, 2001 | 09:25 PM
zerogauge's Avatar
starter sucks
just bought a new starter and had an engine rebuilt and dropped it in the car. starter worked about the first 10-15 times and then it started like...locking up when trying to crank the engine. zings and basically sucks.
would this mean that i need to install shims for the starter or is it possible the starter just needs replaced? it has lifetime warranty so no big deal if i have to take it back
thanks in advance.
Old May 18, 2001 | 10:51 AM
87formula's Avatar
The only thing I would think would make a starter come out and not engage is either A. a chipped flywheel ring gear or B. a chipper starter gear. The shims ussually pull the starter out and away from the flywheel if it binds a bit. I would pull the starter and check both gears if they are okay then try shimming if it still won't work, take the POS starter back.
<font face="Verdana, Arial" size="2">Originally posted by zerogauge:
thanks in advance.
</font>
1987 Firebird Formula
305 LG-4
Crane CompuCam 2030
700-R4 Trans
4 barrel quadrajunk remained by holley (this carb stinks!!!)
edelbrock performer intake
Hypertech Thermomaster Chip
Open Element Air Filter
No Cat with Straight pipe (Dynomax muffler rusted apart and fell off probably could not stand the heat )
Accel H/P Coil
- Soon to be installed
Holly Spreadbore 600
Edelbrock TES
True Dual exhaust or 4 inch single pipe to dual 2 1/4"
1.6:1 Ratio Rockers
Set of New Valve Springs
Pac J
May 17, 2020 10:44 AM
3rd gen money
Oct 11, 2019 09:57 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
