What causes this sound???
Old May 18, 2001 | 07:32 AM
GndPrx's Avatar
What could be a cause of the car sounding like a deisel engine under load? This seems to happen especially when the car first started after sitting for a few hours.
305 tbi L03 is the engine.
It sounds like it's coming from the passangers side down low. My first thought was from the area of the cat, but I can't find it exactly because I can only get the sound while under load. It's nasty loud when you drive next to a wall or something and is more so from the pass side, yet still audible from the drivers side.
I've done a recent tune up and as best as I can tell it's not a knock or ping, just that gawd awful gurgling sound that you would hear from a desiel.
Any ideas?
Carl
CarAudio Resources
Old May 18, 2001 | 10:17 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check for exhaust leaks first, especially around any connections and the muffler. Then check to see if your cat is functioning properly. With the engine warm get a meat thermo and touch the exhaust pipe before and after the cat. The temp after the cat should be hotter...if not, then replace the cat.
The LO3 in my opinion can sound slightly diesel-ish when your revs are low and you in a high gear...but just slightly.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 18, 2001 | 12:15 PM
cbpldc's Avatar
I got a nasty clatter from down low at at any rpm above 2500, but that was my y-pipe vibrating against my SFC's. Check the bolts around where the exhaust manifold bolts to your y-pipe. If these are loose, they would have more of tendency to rattle when the engine is under a little strain. The same thing happened to me.
Old May 18, 2001 | 01:45 PM
Bort62's Avatar
Yeah, Mine makes alot of Funny noise Down there too.
I think its a Venerial Disease.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
