can i use a 305 crank for a 350?
Old Oct 6, 2004 | 09:52 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
ive got a '76 305 layin around and i was just wondering if i could use the crank to put it in the '79 4 bolt 350? just the bore size is different right?
Old Oct 6, 2004 | 10:12 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'm on the same track as you are...I don't see why not. I don't know for sure though, but I don't see it being a problem.
Old Oct 6, 2004 | 10:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I believe 305 and 350 cranks share some of the same casting numbers so yes, I don't see why not.
Old Oct 6, 2004 | 10:20 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
this makes me a happy boy thanks guys
Old Oct 6, 2004 | 11:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The only difference is the balance. The 305 cranks are balanced for the lighter 350 rotating assembly. You can run a 305 crank in a 350, just make sure that the rotating assembly is light. Rumour has it that the LT1 rotating assembly is about the same weight as the 305's, so you can use the crank with that.
Old Oct 7, 2004 | 05:54 AM
ede's Avatar
ede
balance is differant so no it won't work even if it fits. you could have it balanced and all would be well, but for waht that cost you can buy a remanufactured crank
Old Oct 7, 2004 | 11:40 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
It sounds like the solution is to find a set of 305 rods and pistons and have them weighed. Then if you want to use that crank in a 350, be sure the weight of the parts you're buying is lighter.
Seems like it should mainly come down to the piston weight tho, since the 305 and350 use the same rod. Or do they?
I've never bothered to compare the weight of a 305 rod vs 350.
Old Oct 9, 2004 | 02:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes.
Old Oct 9, 2004 | 08:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some do, some don't.
Some 305s come with "X" rods. Most don't.
There's no one single kind of "305 rod" and one single kind of "350 rod". Most of the better ones are marked somehow or have other identifying features.
Right now, I happen to have a set of the GM PM rods (LT4) in my 305. I have no clue where the crank came from though; it's just some 442 casting, could have started out life as either one, for all I know.
The piston weight is largely (although not totally) insignificant to crank balancing, since pistons don't rotate.
Old Oct 9, 2004 | 10:04 AM
Vader's Avatar
Oh, sure hey. The guys in Winneconne or Omro might just bolt it in, but I wouldn't expect someone from Appleton to do it that way. Find a set of LT1 rods as previously suggested, then balance the crank for those rods. Casting numbers aside, the weights are drilled/balanced for the final application at the factory. You'll have to do the same - just try to do a better job of balancing than the factory did. I've seen a few of those '70s engines that had huge variations in rod and piston mass on the same crank. We can do much better.
Old Oct 9, 2004 | 03:18 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I had some slight crank damage when I pulled the 305 apart, my dad gave me a freshly ground 350 crank to replace it. I ballanced nothing basicly just slaped the crank in and did an overhaul of the engine. Latter it got transplanted into a 90 GMC to replace the dead 4.3L. It's still running good to this day, I just wish my ex dident get it
Granted this is vise versa but it would still work. Have you checked local machine shops to see if they have any cranks for sale? Usually you can get a reground crank for under $200.
Old Oct 9, 2004 | 09:17 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
i take it your from WI.
i have the 350 crank, but when my friend was taking one of the pistons out, the stud on the rod scratched the journal. minor scratch, how much would it cost to get it reground and balanced?
Old Oct 10, 2004 | 01:49 AM
Car: '85 IROC
Engine: LB9
Winnecon... Omro?
I thought maybe those were two of Jupiters moons or something.
Oh yes... the crank. It's possible that you could emery paper that scratch smooth yourself.
But then again if you did some serious searching, you could probably find a balanced rotating assy that has all the pieces you need, and use yours as a core.
But if you're really in a pinch for cash a polish job will probably fix it.
Old Oct 10, 2004 | 08:52 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
lol.
Old Oct 10, 2004 | 09:17 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If thats the case $5. Run down to Walmart, go into the automotive or tool section and pick up a scotch brite pad. Cut it to match the journal size basicly 2 1/2 x 6in and work around the journal until the scratch is gone.
Old Oct 10, 2004 | 09:36 AM
JesasaurusRex's Avatar
I dont believe in balancing
Old Oct 10, 2004 | 11:25 AM
Car: '85 IROC
Engine: LB9
Yeah heck . . just buy some parts and slap an engine together.
Build a test stand out of 4x4s an fire that muthah up on the ground, if it runs okay then put it in your car.
If it shakes all over the place, take it apart and have it balanced.
You're prolly gonna screw something else up anyhow if it's your first build, that'll give you a chance to fix that at the same time without having to take the engine out of the car.
Old Oct 11, 2004 | 06:37 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I had a 305 and a 350 crank setting next to each other, they measure up the same but the balance is waaayyy off. The 305 rods are also smaller, and of course the pistons are lighter. Now I guess you could take a 305 crank and rods, add some light pistons and make a 350 that would rev quick. HOWEVER, the 305 pieces are not known for their strength, so the trade-off may not be worth saving the weight. If you put the 305 crank in, you will have to balance it.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
