Clunking Noise When Hitting A Bump Or Sometimes Turning Please Help!!!
Old Oct 6, 2004 | 11:32 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
Ok the other day i was driving my car down the road and went over some railroad tracks. Some bumpy ones.... and after that i noticed that whenever i hit a bump or sometimes when i turn there will be a clunking under the car on the driver side by the wheel and can feel it on the floorboard and on the pedals if my feet are on them at the time. I hope this is nothing major but would like to know what it might be!! Please help!!!
Old Oct 7, 2004 | 12:07 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
You probably have a broken sway bar end link. It makes a lot of racket when they are broken. The sway bar moves around creates a loud clunking noise.
Old Oct 7, 2004 | 12:42 PM
ljnowell's Avatar
Broken strut/Ball joint. Could be the sway bar too. Sway bar is easy to check. Check it first, then check the rest.
Fronzizzle
Mar 18, 2019 08:29 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
