adjusting timing
Old Oct 7, 2004 | 08:37 PM
91redTA's Avatar
Car: 91redTA
adjusting timing
Hi all, Ive searched the boards and didnt come up with a clear answer. Ive borrowed a friends timing light and know to connect it to number one plug and point at the timing marks. I could not come up with where the "brown wire" is to disconnect the ESC and what I turn or adjust to set timing. Any leads to instructions or help would be appreciated. THX
Old Oct 7, 2004 | 09:23 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
The est wire should be on the passanger side behind the front fender well, you need to loosen the the hold down bolt on distributor and turn it to set the timing. I f ia m correct on this 305 's are set at 0*(stock) and 350's are set at 6* (stock)
Old Oct 7, 2004 | 09:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This should help
Old Oct 7, 2004 | 09:36 PM
NascarFool's Avatar
Car: 1989 Iroc-Z
My 89 305 TPI says 6º BTC in Drive on the emissions tag.
Old Oct 7, 2004 | 09:40 PM
Car: 92'Camaro RS
Engine: a loud one
Okay that's probably what it is...i used to have a 305 TBI and the emissions tag read 0* . Guess TPI would be different then.
Old Oct 8, 2004 | 08:20 AM
91redTA's Avatar
Car: 91redTA
Thanks to all for the reply and info. Shifty that pic helps big time!, thx. I hope its as simple to do as it seems.
Old Oct 8, 2004 | 03:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I think all the low-perf motors (LG4, L03) were set to 0* and the hi-perf motors (TPI, L69) were set to 6*.
All of those engines would like 6-8* though I bet. My 350 ('79 Z28) was spec'd to 0* by the factory, and it just loves 8* timing.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
