155 Hp???
Old Oct 7, 2004 | 09:59 PM
turbo_jimi's Avatar
Car: 85 Z28 & 86 TA
Engine: 350 Crate Motor & 305 TPI
Transmission: 5-speed & 700R4
Axle/Gears: 3.23 Open End & 3.27 posi
155 Hp???
My 85 is rated at 155hp and my 98 is rated at 200+. Why don't I have any problems spinning the tires on the 85 and it's almost impossible for the 98. This, of course, is in dry weather conditions. Thanks for the input.
Old Oct 7, 2004 | 10:01 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
The 98's suspension may be in way better shape than the 85's. Tires could be the cause...the 98 could have posi?? The 85 probably doesn't.
I drove a automatic v6 97 firebird and it would spin a lot.
Old Oct 8, 2004 | 12:28 AM
sellmanb's Avatar
Car: '86 Berlinetta
i thought that more depended on torque than it did on horsepower.... either way, it's your suspension, not motor... my mom's 86 buick skylark (4 banger version) can chirp it at half throttle launches at a stop, it's just the suspension sucking, and the tires being overinflated
Old Oct 8, 2004 | 10:39 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Those numbers you gave are peak power numbers. How often are you driving around at peak power? You 85 has more power at lower rpms around the rpms at launch. Now if you had the rpms higher at launch you would have more power.
Old Oct 8, 2004 | 06:35 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You have 250-280 ft/lbs of torque down low on the 85. I believe the 4th gen has 225 or so and it is up higher in the RPMs.
Old Oct 8, 2004 | 10:26 PM
turbo_jimi's Avatar
Car: 85 Z28 & 86 TA
Thanks for the info.
Grumpy
Oct 24, 2005 07:33 PM
smokefan
Jul 4, 2005 12:33 AM
Grumpy
32
Apr 15, 2004 10:28 AM
virtual
Mar 15, 2001 11:44 PM
virtual
Mar 15, 2001 05:59 PM
