compression test results
Old Mar 15, 2001 | 10:57 AM
virtual's Avatar
#1-{120] {140} {150} {155} {160}
#2-{125} {130} {140] {140} {150}
#3-{125} {140} {145} {150} {150}
#4-{120} {160} {165} {165} {170}
#5-{120} {145} {160} {165} {165}
#6-{120} {145} {150} {155} {160}
#7-{125} {145} {150} {150} {150}
#8-{130} {145} [155} {155} [155} and i have oil coming up on #2 plug so do you think its the rings i cranked engine 5 times for the 5 readings
Old Mar 15, 2001 | 11:14 AM
JETHROIROC's Avatar
Could just be worn valve guides, but the way your compression is building up it may very well be the rings. What's your oil consumption like? Does it smoke any? Do a vacuum test on it and let us know what you get. Should be about 18-20in.Hg at idle and steady, and this can help rule out problems such as valve guide wear.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
[This message has been edited by JETHROIROC (edited March 15, 2001).]
Old Mar 15, 2001 | 05:59 PM
ede's Avatar
ede
squirt some oil in any questionable cylinders and if the compression increases you have problems with your rings. all your numbers look good, they should be with in 10%, the actuall number isn't that important. do a leak down test and that may tell more about your engine too.
ICON Motorsports
1st & 3rd
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
87v6Bird
Jul 1, 2018 04:12 PM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
