Car Overheating
Old May 17, 2001 | 08:37 PM
MADOGIROC's Avatar
Car Overheating
I got 89 Iroc and I took the thermostat out. Which one do you guys reccomend?
Old May 17, 2001 | 08:41 PM
AfootVoyager's Avatar
STOCK!!!!!
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old May 18, 2001 | 10:58 AM
87formula's Avatar
170 degree seems to work well, just make sure you replace the time at which the cooling fans turn on or run a switch so you can manually turn it on.
<font face="Verdana, Arial" size="2">Originally posted by MADOGIROC:
I got 89 Iroc and I took the thermostat out. Which one do you guys reccomend?</font>
1987 Firebird Formula
305 LG-4
Crane CompuCam 2030
700-R4 Trans
4 barrel quadrajunk remained by holley (this carb stinks!!!)
edelbrock performer intake
Hypertech Thermomaster Chip
Open Element Air Filter
No Cat with Straight pipe (Dynomax muffler rusted apart and fell off probably could not stand the heat )
Accel H/P Coil
- Soon to be installed
Holly Spreadbore 600
Edelbrock TES
True Dual exhaust or 4 inch single pipe to dual 2 1/4"
1.6:1 Ratio Rockers
Set of New Valve Springs
Old May 18, 2001 | 11:04 AM
Vader's Avatar
MAD,
You might be able to use a 170°F in Vegas without problems, but almost everywhere else I would suggest a 180°F with a stock PROM in an EFI engine.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 20, 2001 | 01:44 AM
jaretz28's Avatar
You know you can try a 170 degree where you live, if you upgrade your water pump to a high flow like I did, I run a 160 in summer. (I don't drive it in winter) Mine is cool in the summer for HOURS of cruising fun.
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
