loose tranny makes banging noise
Old Oct 9, 2004 | 12:39 AM
smokeybandit's Avatar
Car: 1986 IROC CAMARO
Engine: LG4
i dont know guys my car was fine (86 iroc z t-5 tranny) untill the other day all of a sudden it made some strange noise the when i went over bumps its feels like my tranny keeps hitting the bottom of my car. Now i dont know what to do guys also i think one of my motor mounts is shot. I dont know if it has something to do with the motor mount. I have no idea
Old Oct 9, 2004 | 12:44 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
trans mount or tq arm mount....my guess.
Might want to peek under there, just make sure it isn't bottoming out on something.
Old Oct 9, 2004 | 08:19 AM
Damon's Avatar
Easy to check- crawl under the car (properly supported, obviously) and try pushing up hard on 2 things:
1. Tailshaft of the tranny. If the tranny mount is ripped it will be obvious- the tailshaft will lift up fairly easily and the rubber of the tranny mount will be visibly ripped in half. Replace with a poly bushing- they last a lot longer than stock rubber ones.
2. Torque arm that comes up from the rear end housing. It fits inside an enclosed "M" shaped bushing inside a bracket sticking out the side of the tranny. If she's banging around in there on a worn out bushing it will likewise be obvious.
Old Oct 9, 2004 | 10:43 PM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
orjust open youre eyes. j/k
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
