Cranks but wont start.
Old May 18, 2001 | 10:07 PM
87Z-ya's Avatar
Having a problem with my setup on tpi blazer. Its a 165 ecm and it cranks and has spark and fuel pressure but injectors wont fire. If i spray starting fluid in the intake it starts and runs fine, but if i turn it off it wont run again. I checked dist module and its good. This is the weirest thing ive had happen. It was running fine last night and when I went to start it this morning, nothing. Im stumped and getting mad.ANy help please??
Old May 19, 2001 | 05:42 AM
ede's Avatar
ede
well i'm no efi expert but i'd suspect something in the fuel system. i'd check preasure, volumn, FPR, and the injectors.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 20, 2001 | 09:27 AM
87Z-ya's Avatar
Well figured it out in case anyone else ever has this problem. The injectors would lose voltage when I would crank it over. I still cant figure out why it just started doing this after running fine for a while. So I had to tap the injectors power in from a source that still had good power while cranking.
RS Reaper
Oct 17, 2018 07:52 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
