spark plugs
Old May 20, 2001 | 05:36 PM
Trent257's Avatar
spark plugs
i need plugs, should i get the cheap generic $0.69/plug ones or the 3.00/plug ones, wuts the difference, wut improvments are there
Trent
89 Firebird
305 v8
automatic
ttops
Old May 20, 2001 | 05:58 PM
Vader's Avatar
Trent,
Get the original spark plugs (AC R45TS or R45TSX) and gap them at 0.035" (OEM specs). You'll be most satisfied with that. You could get Champion RV15Y64 plugs, but they are essentially the same with plated shells instead of plain steel (less rusting in place). Use anti-seize on the threads in either case.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
