do roller lifters get set with less valve lash?
Old May 21, 2001 | 01:38 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i'm not sure if my lifters are set at too much lash or if the pushrods are rubbing in the heads..
i'm going to double check as i'm using shorter '89 pushrods in '86 heads.. i'd like to make sure the valve lash is set correctly before i go any further though...
so, quesiton remains... is valve lash less turns with a roller cam and lifters as compared to a flat tapper cam?
Webmaster: www.IROC-Z.org
Old May 21, 2001 | 01:40 AM
Guest
Guest
Posts: n/a
No
Old May 21, 2001 | 01:43 AM
Engine: 305TPI
i didn't think so...
damn, i was nervous about the pushrods clearances in the heads.. you wouldn't happen to know why the roller-centerbolt heads have their pushrods guides slightly slotted would you?
pushrod angles as the lifter rides on the lobe? other than that the heads appeared to be the same (beyond intake bolt angles and centerbolt)
thanks man,
Colin
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
