Squeak when turning left only
Old May 20, 2001 | 09:23 PM
Ryman's Avatar
My 88 SC squeaks a little every time i turn left, not at all when i turn right. It's a loud noise, and it's louder and more apt to do it the tighter i turn. I'm sure it has something to do with the steering, but what? Does something need to be lubricated?
Old May 20, 2001 | 11:37 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
It could be the coil spring isolator, or really any of the pivot points for the front suspension. When's the last time you lubed your front end? If it's been a while, give it a shot and see how it does.
Old May 21, 2001 | 06:22 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check your power steering belt it might need replacing, also check your power steering fluid.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
coming soon B&M Quicksilver Ratchet Shifter
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bdads
Aug 24, 2015 06:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
