Oil cooler/filter adapter
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I am planning on using this oil cooler/filter adapter from a 90's 3/4 ton truck and I have two concerns:
1) Why the bypass valve in the center of the threaded pipe where the oil filter goes? It has the one in the normal spot but another in the center.
2) Both bypasses can be pushed fairly easily with your finger. Is this a concern?
Transmission: 4L80E/4L80E
The one in the center is an anti-drainback valve, not a relief valve.
It is different than the 3rd gen oil cooler. The oil itself is routed to the heat exchanger, rather than coolant being routed to the adapter and the heat exchanged within the adapter on 3rd gens.
Transmission: 200R4
Thanks five7. Should I be concerned with the rather weak feeling bypass? Both the anti-drain back and the bypass have the same tension.
I'm getting over my head here. I haven't seen any documentaion, just made assumptions. I'm thinking it may be a thermostatically operated bypass.
I honestly don't know. Toss it in a pot of boiling water and see if it gets harder to open.
tyeo098
Nov 30, 2015 06:27 PM
