Engine eating starters
Old Oct 12, 2004 | 01:39 PM
Camarogeddon's Avatar
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
A while ago, i posted about a fairly new starter that had cracked the bousing which bots onto the engine block.
different suggestions was posted, including the possibility of wrong bolts being used, and shimming.
so, i bought a new starter, new bolts, shimmed the thing as best i could (used 2 shims), it worked fine (tho, it made a bit of a odd noise sometimes) never got around to checking into that, because, today the damn housing split again..
might of course just have been a bad starter, but it seems a bit odd that it should happen twice in such a short time..
any clues or experiences from anyone here?
car is an '86 Camaro Z28 with a 305 TPI .
thanks in advance,
-Camarogeddon
Old Oct 12, 2004 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How does the starter ring on the flexplate look?
Did you check clearance in more than one spot on the flexplate? In other words, did you rotate the engine 1/3 turn and recheck the clearance, rotate another 1/3 and recheck?
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
