Need help, A/C bracket bolts
Car: 89 Formula 350
What size etc.. bolts do I need to keep my A/C smog pump bracket bolted to the heads and block? There WAS one bolt holding it all together (just bought the car recently, didn't notice) I called Pontiac but there diagrams aren't that great. He also told me that two bolts were discontinued and that the other were studs. Since I have no idea what any of these looked like I'm stuck. Any help would be greatly appreciated.
Steve
Steve
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can use any hardware store grade 8 bolts. they dont HAVE to be special ones.
i got stainless steel allen head ones because they look nicer. cost more though.
i had the same problem.... the AC compressor would vibrate like crazy.. so i figured it was going out and went half the summer with no AC.
then when i went to swap the stuff onto the new 400, i noticed that whole bracked was held on by only the two bottom bolts... the rest had vibrated out...
Car: 91 Camaro Vert
oh, sorry... yea they're 3/8" course thread.... like most other bolts on the block.
they're all about the same length except for the one that goes thru where the smog pump was.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Genopsyde
Nov 11, 2015 10:46 PM
