2 problems, 1 solution?
Old Oct 13, 2004 | 09:05 PM
colonboy14's Avatar
Car: Trans Am
1. My car generally doesn't idle that well (jumps around from like 500 to 1000). I think the problem may just be the IAC is dirty.
2. BUT, the car will also stall if a large load is placed on the alt (like holding down the window switch for a few seconds after the windows are already all the way down). Is this the IAC as well, or is something else wrong?
Note: My voltage gauge also jumps around a bit when the blinkers are on. Normal? Or bad alt?
Old Oct 13, 2004 | 09:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check/clean all involved electrical connections first.
Old Oct 13, 2004 | 09:58 PM
sellmanb's Avatar
Car: '86 Berlinetta
if your car is idling at too low a speed then your alternator cant charge fast enough, if that's not the issue then you should take your alternator to NAPA or Advanced Auto and have it tested.
colonboy14's Avatar
Car: Trans Am
What connections are you talking about? Battery terminals and alt? Because it doesn't matter what turns on - headlights, windows, flashers, they all cause the RPM's to go down, and then shoot up to like 1000.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
