Help Priming Motor.........
Old May 21, 2001 | 12:29 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I was priming my motor last night and after just a few minutes I got oil flow through all but the rockers for cylinders 1 and 3. I primed it for another 45 minutes and no oil there. Any ideas? Should I crank (by hand) the motor over 180* and try again, will that help? Seems that these 4 lifters on 1 & 3 are not priming.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old May 21, 2001 | 02:29 PM
camarocowboy's Avatar
You could try that.I just got my new motor in and for a few days I had a clatter because a lifter didn't want to stay pumped,I would rap it up a little and it would quit,then I would kill it start it and it would knock again but she finaly quit.I would suggest the ole fashion way put the starter to it crank it over and start it, some lifters are harder to prime than others.If they don't prime replace them.
Old May 21, 2001 | 10:16 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I primed my engine for 10 minutes then turned the engine over by hand 180 degrees and primed it for another 10 minutes. all my lifters were showing oil by then. You may want to check the pushrods to make sure they're not clogged or anything.
Glowsock
Jul 24, 2025 03:15 PM
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
RS Reaper
Oct 17, 2018 07:52 PM
GTAman
Sep 21, 2015 09:57 AM
