custom cold/ram air cause problems?
Old Oct 15, 2004 | 01:53 PM
phaledax's Avatar
hi ive been out of the loope for a while so sorry for any errors. I got a custom cold/ram air where I used the cooling system air intake (the place where your foglights are) and connected them to my engines air intake (using part of an inertube and some hose clamps) now my problem: ever since then my car runs at higher RPM's at slower speeds example before 60mph was at 1500 now 2100. what could I do to fix this, without taking the ram air out. I have a stock MAFS = mass air flow sensor/ K&N filters. most of the 1987 I-ROC is stock there is only about a dozen upgrades.
Old Oct 15, 2004 | 02:35 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Umm I could be wrong, but that doesnt sound like it's the intake that's the problem. Sounds like the torque converter is doing something strange.
Although I know that driving in cold or rainy weather with your ram air hooked up is a bad thing. I know. So if you're doing that, try disconnecting it when it's overly cold.
But other than that, TO me it really doesnt sound like the intake would be the problem.
Old Oct 16, 2004 | 08:02 PM
phaledax's Avatar
thanks for the help, im gana add a steel screen on the inside of the intake so it wont be seen and now Ill work on a disconnect system, thanks for the idea.
Ghettobird52
Jul 5, 2024 11:18 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
