No ACC, new ignition clyinder
Old Oct 16, 2004 | 07:44 PM
Paipe90GTA's Avatar
Car: 90' TA GTA
I recently installed a new ignition cylinder and have no acc (where you turn the key backwards) i didnt work with my old cylinder but figuered it would with the new one. I sometimes get a beep but not for more then a secound, all my fuses are good. Any ideas?
Old Oct 16, 2004 | 11:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Switch (on the top of the column, down low, near the firewall) needs adjustment.
Old Oct 17, 2004 | 12:02 PM
Paipe90GTA's Avatar
Car: 90' TA GTA
could you be a little more specific, please
thanks
Old Oct 17, 2004 | 03:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ignition switch itself is held onto the column by 2 screws that go through slots in the switch.
You need to loosen the 2 screws and move the switch and re-tighten the screws.
Old Oct 17, 2004 | 04:58 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
There is a rod that runs from your key cylinder down to a box on the outside of your column thats under your dash. Like RB says, loosen the box to adjust so that when key is in ACC posistion that the rod moves the correct selector on the box.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
usafirebird
Sep 29, 2015 11:58 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
