any ideas on this howling noise?
Old May 22, 2001 | 11:15 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
just today it started - when i left to go to work this a.m. i started the car up and right away there's a strange noise, almost like a howling sound, for lack of a better description... it seems to be coming from the rear part of the motor. it's not high-pitch sound... it could be a vacuum leak(?), i'm thinking, although i've never had one, so can't really swear to what that would sound like. the car seems to run fine still, doesn't seem to have any performance problem, it just is making this noise now. It's been more than a year since i've had my intake off and have not done any work in that area since then... if you have any ideas, i'm listening... thanks, guys...
KAM
Old May 22, 2001 | 02:47 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
That's funny...Mine did the same thing last summer. The sound I heard was more like a whisle, and it was even loud enough to hear inside the car. The sound happened when I relocated my MAT sensor to the air ducting. I plugged the hole with a pipe plug (or something I dont' remember) I think it created an orifice to whistle as the air moved in the plenum much like blowing over a bottle top does. Does yours rise in pitch with rpm? I simply screwed the plug in further and the whistle stoped. One of those funny quirks... I probably didn't help you much, but maybe it will help trigger some ideas...
Mint black/black 1987 T/A GTA 305 5-speed, 55K,
3.45 factory POSI,SLP cam, SLP runners, Taylor wires, hurst comp plus shifter, K&N conical rig, AFPR, coated shorty headers, no cat, no smog, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 160 stat, SFC's, lower control arm adapters, Aluminum Driveshaft, ported upper and lower, Mobile ES and 10 disc, kickers all around and q-logic kick panels...Perf 350, rear batt, lowering springs,cowl hood, & NOS coming soon!
Old May 22, 2001 | 03:12 PM
Scott C's Avatar
Alternators tend to whine just before they go bad. How is your voltage? Just a thought...
Old May 22, 2001 | 09:16 PM
Car: '91 Z28
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by Scott C:
Alternators tend to whine just before they go bad...</font>
BINGO!!! I don't know why I didn't think of that earlier, cuz that's exactly what it did last time (many years ago). I didn't even think about it, and after I got home, I got the ol' stethescope out (those things are so cool)and that was the first thing I checked. Once I found that, I looked at the ol' voltmeter and sure enough... Now if it stops raining I can change it... Another lifetime guaranteed part that I can't trade in cuz there ain't none of them stores around here!
Thanks for your replies...
KAM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
