What all should I take out with A/C delete??
Old May 23, 2001 | 12:53 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I've taken out the pump and the cond. and the high pressure lines and I'm going to take out the cooler in front of the rad.
what else should I take out???
also should I see any better cooling when I take out the cooler??
Thanks any info you have will help
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old May 23, 2001 | 01:01 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
dont expect much from removing the cooler (as far as better cooling....it just gives better access for leaves and bags to block off your radiator instead of the cooler....whats it called again (evaporator?)
did u remove the silver canister thingie?
you can remove the big black thing that the silver canister connects to....not sure how...but ive seen pics with out it...i think you need some special heater core then though....so dont quote me...and mess up your car mine is still on there
Old May 23, 2001 | 01:09 AM
IROCU69's Avatar
Car: 85 Sport Coupe Camaro
Engine: 1969 Camaro 350
Transmission: TH350
Axle/Gears: 3.73 Posi
well heres what I did when I removed all that... however I think I went further then what you plan on doing.
I removed the compressor, lines, ac cooler, the blower motor and cond., that whole plastic mounting piece on the fire wall and the dash climate control. I put switches for my fans and switches for other things heh in the dash spot. It also free'd up a lot of space in the engine bay and I'm putting a trans and oil cooler it its place. On the fire wall I cut a piece of aluminum to cover up the hole and just bolted it up using the factory bolt holes for the plastic blower/cond mount. I have an 85 Camaro however I also have a 91Z28 serpitine belt setup, same one as you no doubt. When I removed the AC I put the 1LE AC bypass pulley in. You absolutely have to do this since the water pump runs off the back of the belt. Hope that helps.
-Mike
Old May 23, 2001 | 01:17 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
I've already got the GM pulley in place now
I was just courious what else I should take out I have to keep everything smog legal
I took out the heater core already so I guess I have a lot of crap I could possibly take out to clean it all up..
any other info will help
thanks
Hecubus
Old May 23, 2001 | 01:23 AM
Car: 90 Camaro RS
Engine: 305 TBI
first of all...you dont absolutely HAVE to have that pulley...i dont...u just have to reroute the belt so that the water pump runs in the same direction as before.
id take out that black plastic thing on the firewall...it looks MUCH cleaner.
Old May 23, 2001 | 07:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You could go to a junkyard and find an older cam/fb without a/c and steal the blower motor housing. Make sure to take the 'squirrel cage' off the blower motor as the non a/c one is not as wide.
Also the resistor pack in the non a/c cars is square and the one on the a/c cars are triangular. A minute with a die grinder and it fits right in and looks 100% stock.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old May 23, 2001 | 09:27 AM
jayman350's Avatar
What is involved in removing the black piece from the firewall? I am going to be doing an engine swap and I figure that will be the easiest time to get rid of it.(A/C has been out for a while)
Jay
black 85 Z28, t-tops, 4bbl carb, flowmaster 80 series muffler w/ custom tips (hollowed out cat), edelbrock chrome air cleaner, B&M Megashifter Infinity 4" 2 way front speakers and Infinity 3 way 6x9s, Alpine CDA-7863 head unit. MacEwan motorsports white gauge overlays, blue Xenon bulbs. many more mods planned (350 4 bolt main w/ holley 4160 and edelbrock performer RPM intake coming very soon)
Jay's webpage
Old May 23, 2001 | 10:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Some of the screws holding the heater/evaporator box to the firewall are easy to get at; they're on the firewall. For others (two or three? They hold the lower part of the heat/evap box to the firewall), you'll have to go underneath the dash, from the inside of the car. Just look for the silver screws (10mm)- they're easy to spot underneath the dash.
I noticed a slight improvement in cooling with my condensor gone from in front of the radiator... maybe 10 degrees or so...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
