anyone running seamless aluminum fuel line???
just picked up a 25' roll of 3/8s line for PJs GTA. Is this going to be okay to be used on the street as long as its clamped down well? Have you guys that are running it had any problems, or comments. I took all of the stokc plumbing out and was planning on running this but I thought Id ask first and make sure you guys have ahd good luck with it.
Thanks,
Randy
Currently own: 2001 Xtreme, 85 IROC, 87 S10
pics of my old 86Z:
Camaro1 Camaro2 Engine
More at: My Directory
Email: MeanYellowZ@hotmail.com Aol/IM: RCY1980
Thanks,
Randy
pics of my old 86Z:
No problems with mine in the last six years Randy. The nice part is it's easy to bend around where you want it. I just put mine in the stock location and clamps.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
1984 Z28 350
My Web Page
I knew that you said you were running it les, but the guy at winners circle got me worried by telling me that it was not good for the street, so I thought Id ask around.
although, I still would like to know from someone who actually drives theor car, how its held up. lol, j/k man
Guest
Posts: n/a
I was gonna ask this too, but I figured if they sell it, and many people use braided line, it must be ok.
Just make sure its away from anyplace someone might jack the car up.
btw, this weekend I am installing a 1/2" feed line and 3/8" return line made of the stuff, so it better be ok!
[This message has been edited by madmax (edited May 22, 2001).]
Car: 1986 Firebird
Engine: 2.8 V6
Won't aluminum melt faster in a fire? Of course fire's dangerous enough to a car, but this might make it a little more? Don't park over any weeds or dry leaves.. not like you do that now, but...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
I'd be CAREFUL using aluminum line on the street. Not that I wouldn't use it at all. Just be CAREFUL.
Here's why: Aluminum line rubbing against another metal part will wear a hole in the line is a SCARY FAST HURRY! It has nowhere near the scuff resistance of a steel line. So make sure the clamps you use are lined with rubber or plastic- not metal on metal. And make sure you don't run it near anthing that it can rub against as it vibrates or as the chassis flexes.
I wore through an aluminum fuel line once in only 5000 miles of driving. It was rubbing ever so slightly on a hole through the frame which it passed through (I duplicated stock routing). Suddenly I'd have puddles of gas waiting under the car every time I went out to start it.
Transmission: 4L80E/4L80E
I picked up some of that nylon spiral wire bundle stuff to put on the line in potential rub areas. I just put the Al line on the '57 this spring, but so far, no problems. It's a joy to work with compared to steel.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
ADEL clamps will hold it nicely. i would stay away from gas driers like HEET, alcohol corrodes aluminum rapidly.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
