Heat question
Old Oct 22, 2004 | 05:23 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Heat question
I'm looking at an 89 Formula w/ carb'd 350/700r4....doesnt have the A/C stuff hooked up...thats fine, but it does get pretty damn cold up here in MA, and I hate driving to school freezing, lol
Any easy/inexpensive way to heat the car? i'm looking for at least somewhat serious replys, so no, i am not going to route the exhaust through the car itself to heat it up, though its not a bad idea, LOL
Sorry if this is the wrong section.....didnt know where to post this...
thx
Old Oct 22, 2004 | 08:51 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Are you positive that the heater core hoses are disconnected? If all the air conditioning stuff is unhooked but still in place on the firewall, and your heater core hoses are hooked up, and your blower motor works, you should have heat unless your coolant level is low.
If you do not have heater core hoses and the blower moter workes, then install the hoses and be done with it.
If your firewall has no ac box at all and there are two big holes were it used to be, then you are in the same boat I was in, and I had to fab a heater box that puts the squirl cage of the blower centered over the round hole and routes the air to the square hole, I made one out of a 1978 chevy truck heater box that didn't have ac. I had to lengthen it 3 inches with sheet aluminum, then change the resistor for the speed control (located near squirl cage in heater box) over to the stock TransAm resistor (a little cutting of the trucks heater box and it fit perfectly).
Hope this helps.
EDIT: You could also try to find a heater box with a blower for the 3rdgen F-Body that has no ac and just install it with no modification. But they are pricey, I have not seen one sell on ebay for less than $100.00 (when there is one for sale) and have not found one at a bone yard yet. But look around you may find a deal.
Old Oct 22, 2004 | 09:24 AM
pretty sure ALL the A/C stuff is out of the car....dont think the guy has any of it either.....
Maybe i'll head up to Camaro Heaven in NH, they've GOTTA have what i need...dunno what they'll charge though....
Old Oct 22, 2004 | 06:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You could use a small electric heater the plugs into the cigarette lighter. This is probably what i will end up doing, but i also probably won't be driving my camaro in the winter. I have seen them in the JC Whitney catalog www.jcwhitney.com
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
