Something wrong with starter/starting system
Old May 24, 2001 | 10:39 AM
Mike89GTA's Avatar
A couple weeks ago I went to start my car and it wouldn't even click. Usually I would have to turn the key once or twice because the starter solenoid was old. So I just replaced the starter and solenoid figuring that was the problem. I go to start it now.. nothing. No click or anything. I have a kill switch mounted in line with the clutch pedal switch so I guess it could be something wrong there. Ever since I installed that it seemed to have a little less starting power. I guess I'll check the switch next. Is there anything else that would cause this? A sensor, etc.. The fuseable links looked ok when I replaced the starter.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old May 24, 2001 | 10:47 AM
Mike89GTA's Avatar
PS I replaced the + battery cable while I was at it and the battery is relatively new. The lights, guages etc work fine so there's plenty of juice.
Old May 24, 2001 | 11:40 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check your plug wires, dist cap and rotor for corrosion lately?
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 24, 2001 | 11:46 AM
Mike89GTA's Avatar
Hmm, yea I'll have to do that. Thing is the solenoid doesn't even go out or "click" which means either a fuseable link is bad (I've checked the ones under the dash near the clutch pedal switch (2 I think..) and the ones by the starter. Maybe I'm missing some..
Old May 24, 2001 | 12:19 PM
Mike89GTA's Avatar
I just rewired it so the clutch pedal switch and kill switch weren't in the circuit and it still wouldn't start. So maybe it's one of the fuseable links by the starter.
Old May 24, 2001 | 05:32 PM
Bubba's89GTA's Avatar
Does your 89 have a VATS system, have you tried another key? Try searching the archives under "VATS". It helped me out when I had to trouble shoot mine.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
Dyno Don
Jan 24, 2016 08:24 AM
