Overhaulin'
Old Oct 25, 2004 | 08:48 AM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Overhaulin'
Hey, what's up y'all? I was just wondering what the average price for an engine rebuild kit is for my 305? Also, I was wondering what came with the kit. Thanks.
Old Oct 25, 2004 | 11:00 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
stock kit is about $175.
the kit contains:
1-pistons
2-Rings
3-cam bearing
4-cam (optional)
5-crank bearing
6-freeze plugs
7-rod bearing
8-gasket set
9-oil pump, screen, and guide
10- some other parts that I forgot
I hope this will help
Old Oct 25, 2004 | 11:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't waste your time with the 305 unless you do not care about performance. A 350 build will cost you about 50 bucks more.
Old Oct 25, 2004 | 11:04 AM
ede's Avatar
ede
price depends on what parts and how extensive the kit is. in reality there is no such thing as a kit as far as they go and pull it off the shelf. what happens is you tell them what you need and specs such as over bore or undersize and they fill a box for you with the required parts. buying a "kit" in no way means you get all the parts you need.
Old Oct 28, 2004 | 09:20 AM
Slim86TransAm's Avatar
Car: 1986 Trans Am and 1976 Grand Prix
Engine: TA=305 GP=350
Transmission: TA=5 speed GP=TH400
**** it. Switch engines w/ Edward when he's not looking... he'll NEVER know. That'd be funny as hell.
Old Oct 28, 2004 | 11:51 AM
ljnowell's Avatar
305 rebuild kit 175 dollars.
Fluids and Extras 100 dollars
Wasting your money on a 305, PRICELESS.
Old Oct 28, 2004 | 01:05 PM
A88GTANotchback's Avatar
i cant get over how many of you ppl are so anti 305. ive seen many 305's go fast. sure its easier to do with a 350(the way im goin) but i know many ppl building 305's that would most likely SPANK alot of 350's out there. if someone wants to build a "boat anchor" let them do it and give them feedback that actually helps with the question.
Old Oct 28, 2004 | 01:14 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
it is actual feed back that helps ...
if he or anyone for that matter is building a 305 for performance reasons then they either:
A... have more money than they now what to do with .
B... dont know what they are doing
C... want to keep the car numbers matching
D... have never built an engine before and dont realize the potential of building a 350 over a 305.
here is a url to a place that sells master rebuild kits ...this doesnt cover the machine work involved or assembly or fluids or filters or anything besides engine internals
http://www.northernautoparts.com/Pro...ctModelId=2356
Old Oct 28, 2004 | 01:54 PM
Car: 1989 Camaro RS
So would it be cheaper to just put in like a crate 350? 'Cause my little 305 ain't fast, but it ain't slow either. I'm really looking to save a little money if I can, so whatever is cheaper. Thanks
Old Oct 28, 2004 | 02:50 PM
THEGENERAL's Avatar
well first off is emmisions a problem where you live at ????
if it isnt then you have alot of options as to what to do
Old Oct 28, 2004 | 03:18 PM
Emissions are DEFININTALLY NOT a problem where he lives.
Old Oct 28, 2004 | 03:24 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Ya know what gets me?
THERE'S NO REPLACEMENT FOR DISPLACEMENT!!!!!!
...and he wants to build a 305
Man if you're going to go through the trouble of ripping the motor out and rebuilding it, just drop in a 350. As for my car, I'm doing as much stuff to my 305 as possible as long as the parts will transfer to a 350. The only reason I'd possibly consider rebuilding my 305 is if I do end up deciding to twin turbo it because the turbos I would use probably won't support a 350, but should support a 305 until I'd upgrade the setup.
Aside from that, 350 it is. My plan right now is to go as far as I can with the 305 (speed-wise / mileage-wise) until its either no fun any more or not running, and then I'll build a 350 to put in. As for now, I'll be content with my little rev-monster
Andy Fanshawe
European Region
19
Aug 14, 2009 05:29 AM
Psycho_91Camaro
Southern California Area
May 20, 2005 05:40 PM
CashMunson
Aftermarket Vendor Review
Oct 28, 2004 10:55 AM
cthuluwaits
Aftermarket Product Review
Oct 25, 2004 11:20 PM
Dante93GTZ
Oct 5, 2004 10:16 AM
