Supporting Engine while tranny is out.
Old Oct 25, 2004 | 12:14 PM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
im going to pull the T5 in my 84 camaro for a rebuild. The problem is, i will be moving soon and need to move the car also. i wanted to know a way i can support the engine while it will be on a car dolly. for now ill just leave a jack and block of wood under the oil pan, but when i comes time to move i will need a way to support the engine without the use of a jack underneath. does anyone know of a way i could do this so i wont bust up my dizzy when i let the jack down? thanks alot
Old Oct 25, 2004 | 04:05 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I don't know of a way to do that, but I wouldn't try move it at all without a tranny installed.
Old Oct 25, 2004 | 04:08 PM
Damon's Avatar
Find a bolt hole on the back of the engine you can run thick coat hanger or welding wire through. Use that to strap it up against something strong on the firewall or cowl area. There's still a bit of weight to it, but the engine mounts are doing most of the work.
Strapped up plenty of trannys this way (which are, admittedly, lighter) but I don't see why it wouldn't be possible to do the engine in a similar way.
Old Oct 25, 2004 | 04:10 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
double post edited out...
Old Oct 25, 2004 | 04:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you have an engine lift loop on one of the front intake bolts (mine did, drivers side) then put a chain on that and put that chain up to the rad support or a part of the frame.
Actually, if you still have the exhaust system on it, that might be good enough.
Old Oct 25, 2004 | 06:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why?!?!
Anyway, I usually use one or two bolts in the rear of the block and then tie them off somewhere. Then I move the car without a tranny.
Old Oct 26, 2004 | 06:53 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Red Devil
Why?!?!
In 15 years, i've never seen a motor fall out of a car, or break anythign when the tranny was missing..
-- Joe
Old Oct 26, 2004 | 08:08 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
We're obviously are doing things the wrong way Joe.
Old Oct 26, 2004 | 08:13 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
-- Joe
i couldnt agree more we move them around everywhere without a tranny in the vehicle but as for towing one long distance i still dont think it would be a problem at all but if you fee the need put a 2x4 behind the engine between it and the firewall and let the engine rest on it that way you dont have to worry about it "falling out"..LOL...
i dont think it would anyway
Old Oct 26, 2004 | 11:20 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Remove the distributor and the motor will tilt back all it wants without breaking anything... Last time I installed my transmission I used a tow strap to keep the motor forward. Roped it around the accessory brackets and then around the rad support. click-click-click, its sitting forward.
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
