Stroker Kit on 350 TPI
Old May 25, 2001 | 12:37 AM
chevySS's Avatar
Would it be worth it to put a 383 stroker kit in a 350 TPI? what would be the gains on a stock motor? what about on a motor with performer RPM heads and a mild street/peformance cam?
[This message has been edited by chevySS (edited May 24, 2001).]
Old May 25, 2001 | 07:10 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
It will give the car even more low end. You should at least use some type of aluminum head (factory or otherwise). As long as you don't have traction problems already, your in good shape.
383s are torque motors not rpm motors. Keep gears to 373 or higher numerically
Old May 25, 2001 | 10:16 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
<font face="Verdana, Arial" size="2">Originally posted by jcb999:
Keep gears to 373 or higher numerically</font>
Why?? It seems to me that you would want to keep the atio to 3.42 or lower due to the increase in off the line torque. 3.73's will yield traction problems in a properly built TPI 383, and will give up too much at the top end, as the engine rapidly leaves the TPI's tuned powerband. 4.11's would be even worse.
By the way, I have a 383 stroker assembly for sale for 2-piece rear main seal applications: I just need to finish weight matching the forged pistons. I'm selling for $325 if you are interested.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
Old May 25, 2001 | 12:46 PM
chevySS's Avatar
Thanks for the info guys.. I am currently looking for a 350 TPI Z28 to buy.. and I was toying with the idea of putting a stroker kit in it.
Old May 25, 2001 | 01:48 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
your right..tempoary brain fade... I meant lower numerically (as in 342 or 323). It was too early to be replying..
I would not say that you would have traction problems with a 383/3.73 combination. I have 4.10s on my 400 and it works good from about 10mph. (but it's not a tpi)
[This message has been edited by jcb999 (edited May 25, 2001).]
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
