What Will Help MPG?
Car: 99 Formula
Axle/Gears: 342
What Will Help MPG?
I was wondering what can help me get better gas milage. Would a new intake help at all over the stock aluminum one.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
Car: 2006 Silverado 1500
Engine: 5.3L
synthetic fluids, aluminum driveshaft, headlight covers, fiberglass hood with cold air induction, aluminum brake drums, etc, etc. keep everything light, aerodynamic, and keep the air going in and out of the engine low on restriction and cool.
Car: 2002 SOM z28
Gearing is where the main savings can be made. I see you all ready have 2.73 gears and a locking converter... now does it lock? It won't if you've bypassed the computer and not installed some sort of switch (vacuum kit available or manual switch). Leaning out the carb can have an effect too along with a lower stall converter. Driving habits play a role too. What kind of mpg are you looking at now and what do you want? I doubt you'll see 50mpg, but 25-30 isn't out of the question with your set up. I get 25 on the highway.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
If you have a Locking COnverter, it dosent matter what the stall is
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Car: 99 Formula
Axle/Gears: 342
The guy who rebuilt the tranny gave me another TC I don't think it was new but I believe he said it was hydrualic so it will lock on it's own. Does this sound right?\\
Before I had OD I was getting 14 mpg, and now I am getting 16mpg.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
Car: 99 Formula
Axle/Gears: 342
So how do I go about fixing this?
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
Car: 2002 SOM z28
Do a search of the tranny board for lockup switch or vacuum switch and a few of my posts will come up about a TCI kit or B&M kit whitch you install in the tranny and it locks up the converter in 4th gear.
Bort- what about converters with different flashes? I would also assume that if you split hairs, a converter that slips more will use more gas then a stock converter... True, when they lock, they lower the rpms about the same amount, but they usually aren't locked in 1st-3rd gears, right?
