Antifreeze leak! GOD HELP ME!
Old May 24, 2001 | 05:30 PM
85T\A's Avatar
OK here goes, last year before I put my car away it had a leak which I thought was the water pump. So while I was painting my car I pulled the old one off(It was loose also)and it looked like it had been leaking! So I replaced it and guess what yup it still leaks
And the kicker is only when I drive it!WTF It's not from the WP and I don't know what else to do! No water from the exhaust, HELP!
Anybody else have trouble like this?
Oh and it's on the passenger side front of block...
85T\A 305 TPI Auto WS6 3:43 Edelbrock TES headers Jet Hot Coated,Air Foil,Hooker Cat Back,SFC's,B&M Mega Shifter
STB,AFPR,50000 org miles
[This message has been edited by 85T\A (edited May 24, 2001).]
Old May 24, 2001 | 08:25 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Isn't there a freeze plug up front there, behind the pulleys? If not perhaps the intake manifold gasket has given up on the water jacket up front. Any water in the oil?
It probably only leaks while running cause the coolant is under pressure. Is the water coming from the front of the block or from the intake manifold by the heads? Could it be seeping under the thermo housing? More info please.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 24, 2001 | 10:13 PM
86 IROCZ28's Avatar
Soem other places where it could be coming from are:
Knock sensor
Temeprature sending unit
Radiator hoses loose ,Water pump seals defective, leakeage from radiator core or header tank, engine drain plugs or water jacket core plugs leaking.
So you can see puddle of coolant under the car when it is stationary?
Old May 25, 2001 | 07:35 AM
85T\A's Avatar
No water in the oil, and no puddle under the car I've checked the radiator it's dry, I'm going to look for a pressure tester today and try that and see if I can get a better idea, It looks like it could be coming from the head gasket just behind the alt. but it's really hard to tell the exact place. The water pump and temp sending unit are dry.
Old May 25, 2001 | 08:07 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I doubt that any gaskets are leaking since you don't have water in your oil. You would see obvious evidence if any connections to the block were leaking (ie CTS connection).
I suggest you take a good look at your hoses. You probably have a hairline crack in a hose which looks and works fine when the engine is cool, but fails under significant pressure. Just my .02
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 25, 2001 | 09:32 AM
85T\A's Avatar
Thanks I'm off to the store to get a pressure tester to help me find the leak. Man I hope it's just a hose!
Old May 25, 2001 | 10:39 PM
86 IROCZ28's Avatar
One other thing you could do is pressure test the radiator cap. That could be the problem also.
Old May 26, 2001 | 05:15 PM
85T\A's Avatar
I found it! It's in the manifold base DAMN! Good thing I nave a long weekend to fix it and clean up the ports! POS! Thanks for all your help.
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bschmale66853
Sep 30, 2015 08:11 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
