Car Barely runs when cold
Old May 26, 2001 | 09:25 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
on my 89 350 TPI when i start it I have to let it warm up 8-10 minutes before I can drive away smooth. If has the problem beween idle and 2,000. Sometimes If i hit the gas it seems its going to die and the whole car will go pu pu pu pu. Everything thing is brand new on it plugs wires blah blah timing is at stock 6 FP is at 46-47. I'm thinking a bad maf maybe even though I am not getting any codes.
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, MSD 22# Injectors, Hoping for 13.5
Old May 26, 2001 | 09:30 AM
Vader's Avatar
Mkos,
Of all the sensors monitored by the ECM, the MAF is one of them that is most closely monitored. If the MAF signal varies from the acceptable range for more than 600mS, you will get an error code. It is possible that you have stored a pending code that may not be setting the MIL lamp, so scanning for any DTCs would be a good idea, but I'll be a little surprized if you turn up a MAF error.
If may have more relevance to teh CTS and TPS sensor readings than the MAF, and both of those can be checked easily with a meter.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 26, 2001 | 11:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
With my OTC scanner the TPS is .54 what should the CTS be at?
Wade787b
Sep 29, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
