VATS problem
Old Oct 31, 2004 | 12:27 AM
HI85WH1's Avatar
Car: 1992 B4C
Engine: L98 5.7 liter
Transmission: THM 700-R4
VATS problem
'89 RS 5.0 TBI/700R4....
Intermittently, the car wont turn over (wont crank)... security light does NOT cycle off as it should... I am assuming it is the VATS acting up... is there a way to delete this feature without burning/buying a new chip?
EDIT... after some searching... it looks relatively easy...
If I determine the resistance value of the key (assuming I can measure across both sides of the key) , then I should be able to duplicate the resistance with common resistors available from radio shack... correct? The only thing is where would I splice these resistors in-line? The connector below the steering column?
a previous owner had the same problem.. which is how the car came to be in my hands....
any help would be greatly appreciated...
Robert
Old Oct 31, 2004 | 09:20 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
You're on the right track. Just find a wiring diagram and cut the wires and put the resistor across them. Might go to the dealer and have a new key made, might help the problem but those keys are about $25.
Old Oct 31, 2004 | 11:11 PM
HI85WH1's Avatar
Car: 1992 B4C
tom3,
thanks for the reply... I think it's simple enough to splice the resistors into the plug under the dash... but I've been lucky thusfar... the car hasn't let me down lately...
I guess I will stop by radio shack tonight...
Rob
Old Nov 1, 2004 | 12:09 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I did exactly that after one of the wires to the key cyllinder broke on me... and it works...
I don't use it, but it's always an option if I have the same problem again... I'm implementing other security measures as well so I won't have to depend on my key beig measured...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
