This sucks
Car: 1986 Firebird
Engine: 305 V8 Currently being rebuilt
Transmission: 5 spd
This sucks
My car all of a sudden has a kiss of death. It was running great then all of a sudden it feels like its running on 4cyl. (Its an 8cyl)
I've checked the spark plugs/wires, distributer, choke, timing and fuel filter. Everything was fine. Then I started it up and lo and behold I hear a cling cling cling... I put my hand on the drivers side valve cover and you can feel it knocking. What can I do to fix it (besides get a new engine)??? Its an LG4 P.S. Could it be the camshaft and lifters wore out??
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Take off the driver's side valve cover and see if there's anything loose. Sounds like it could be a loose rocker issue.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
how many miles does this car and engine have on it??
have you ever readjusted the valve lash before??
I know this sounds too simple, but check your oil level and oil color for other problems, a chocolate milk color is very bad. I would not start it up again untill you find out whats wrong. Hopefully the noise is something loose under the valve cover and not an engine problem.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
3.8TransAM
Oct 1, 2015 07:47 PM
