When did GM start to put computers in cars?
Old Oct 31, 2004 | 07:40 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I was to say 87 for most GM products outside of the TPI, but enlighten me.
I was looking to my next project, and I want it to be a carb motor, so the least amount of computer controlled garbage, the better.
I've been looking at Caprices specifically, but who knows . . .
Old Oct 31, 2004 | 07:56 PM
ljnowell's Avatar
Im pretty sure that every carbd car since 82 at least had the computer and CC Qjet. My 82 olds did. Every american sold thirdgen did. I know that pickups in 81 didnt, but as far as cars, I think all did past 82.
Old Oct 31, 2004 | 08:00 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
The 81 camaro had a computer controlled carb.
Old Oct 31, 2004 | 08:32 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
A long time ago my uncle had told me all cars since 1980 1/2 (effectively 1981 since there weren't any "1/2" models since the 60s) had some form of a computer onboard..
Then again, as above stated, it appears trucks didn't have a computer at all in 1981. Maybe trucks were a year later?
Old Oct 31, 2004 | 09:57 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Funny thing, neither my 83 nor 84 Camaro's came with ECM's from the factory.
83 had the 2.8, and the 84Z had the LG4.
Old Oct 31, 2004 | 10:10 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
They have to be Canadian or export cars then. All 3rd gens sold in the US had to have computers due to gov regs.
Old Oct 31, 2004 | 10:39 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Most Canadian cars had computers too. I had an 82 X-body with the H.O. 2.8 and it had a computer controlled carb also. I have heard the rumor that SOME Canadian cars didn't come with a computer (when they should) and I always suspected they were "pulled" by someone.
But as someone else said, 1982 (maybe 81 for a few) was generally the year the majority of GM cars came with some form of computer (even if they only had a carb).
Old Nov 1, 2004 | 01:04 AM
ljnowell's Avatar
There were a lot of canadian cars without the computer setup. But all american ones had it. Although, I would prefer to not have it, which is why I dont.
Old Nov 1, 2004 | 03:45 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
didn't the late 70's cars come with Qjet carbs?
Old Nov 1, 2004 | 06:07 AM
Vader's Avatar
Engine management processors first appeared in 1976 on some GM models. 1977 brought more processors on more models. Most domestic GM cars had some form of processor by 1980.
Old Nov 1, 2004 | 11:03 AM
ljnowell's Avatar
Many 70s cars came with the qjet, but not the computer controlled one.
Old Nov 1, 2004 | 11:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by Glenn91L98GTA
Most Canadian cars had computers too. I have heard the rumor that SOME Canadian cars didn't come with a computer (when they should) and I always suspected they were "pulled" by someone.
The LG4 in the Canadian thirdgens wasn't computer controlled.
Old Nov 1, 2004 | 03:32 PM
Car: Death Mobile
Engine: 666 c.i.
Not all. I was involved when BC went emissions testing and they had to track down what emission equipment came on what cars in Canada.
Yes, it was found that some manufacturers DID NOT comply with the required emissions and gave "Export" cars instead of "US Federal Emission" cars. But it was more a "hit or miss". No one model was found to be exclusively "Export". It was more "the majority were US Fed but a number of Export ended up in certain parts of Canada.
However, now for the bad news, just because your car is built "Export" doesn't exempt it from BC emissions testing (if you live in the Lower Mainland of BC). In fact, for a lot of models, the BC emission requirements are LESS than California. They lowered the emission limits on my 1991 GTA below California standards (before I relocated to Kamloops which doesn't have emission testing).
Since 1992 ALL cars brought into Canada MUST meet have minimum US Fed emissions - no more Export cars to fill the gap. That is why in BC, if your car may fail emissions and it was built in 1991 or earlier, you can obtain a "waiver" if you spend a minimum amount (use to be $150) to attempt to bring your car in compliance with the emission standard. If your car was buillt in 1992 or later, you have to spend "what ever it takes" to make it pass.
Thus, if you want to modify your engine, 1991s and earlier are the vehicles to get. You only have to spend the minimum amount to "attempt" to make it pass emissions.
Old Nov 1, 2004 | 04:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not all, no, but certainly the vast majority. The older it is the more likely it is to be non-CCC.
Old Nov 1, 2004 | 07:18 PM
Car: Death Mobile
Engine: 666 c.i.
Personally, I consider them to be "lucky". No one would touch my 1982 X-body with the computer controlled carb. And that carb (it was a two barrel with a primary and secondary) was hard to find and very expensive.
Old Nov 1, 2004 | 08:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
But that was back in the day when everyone was used to conventional carbs and nobody understood computers. Now the opposite is true.
Old Nov 1, 2004 | 09:15 PM
Car: 91 RS
Engine: 350 TBI
Exactly how would a computer control a carb?
Old Nov 1, 2004 | 10:00 PM
ljnowell's Avatar
Sensors for metering airflow etc. Sets richness via ECM. It is actually a really nice setup. Do a search for CC Qjet, and you will find lots of threads.
Old Nov 1, 2004 | 11:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The primary metering rods are raised and lowered by a solenoid, instead of by vacuum. When the mixture is rich, the rods are lowered, when the mixture is lean, the rods are raised.
bryan623
Mar 22, 2021 06:43 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
