removing the AC radiator thingy.
Old Oct 31, 2004 | 11:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
in front of the radiator, u have that other radiator wannabe thing that has the two ac lines running into it. what is the purpose of that? and if AC is removed, can i remove that as welL?
Old Oct 31, 2004 | 11:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
AC condensor. Yes.
Old Nov 1, 2004 | 12:03 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Yep held in by a rubber mount at each corner and there's some foam between it and the radiator on the sides. I think to get mine out I dropped the two thin cross bars and loosened something else. Its pretty obvious what to do when you're under there and wasn't too hard to get out. Doesn't weigh much at all but it does allow air to get to the radiator a bit easier and makes room for more cool air to go around the radiator on the sides and enter the engine bay as well. I used this to modify the stock air box on my Trans Am to suck in cooler air.... don't know how big of a difference it made, but going to a true K&N cone-in-fender CAI made a big difference.
Old Nov 1, 2004 | 02:41 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, that's the AC condensor. I just removed mine by unbolting the fan(s) and removing them, unbolting the radiator and tilting it towards the engine as far as it will go, and then slowly pull the condensor up and out. It's that simple.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
Bohemian
Aug 15, 2017 05:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
