What makes a tpi engine start up quickly?
Hey all. I've got a '91 Camaro Z28 with a 350 tpi motor. I've been really impressed with how it starts up so quickly-at the tap of the ignition switch on the steering. What are the key components that make a Chevy engine start up quickly ?
Its not that its a chevy. Its the fact that it is a fuel injected engine with proper ignition. Good plugs wires cap and rotor, and fuel injection. Its a good combo for reliability. I just dont care for TPI when it comes to performance.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Originally posted by Xceleratemaro
id say
the starter...
id say
the starter...
Fuel injection has NOTHING to do with it, and neither does the fact that its a Chevrolet. Of all the injected cars I've owned, none starts up quicker than my car, which is carbed.
You need decent compression, a strong starter motor, proper fuel delivery, and a STRONG spark. Most associate carbs with poor starting, but that's due to tuning issues.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
The quickest starting cars I've ever had were carbe'd, though my '96 Chevy 1500 (vortec 350) starts in about 1/2 a revolution.
"Ra.....LA-la-la-la-la-la-la-la-la..."
I love that.
-Tom
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Originally posted by ljnowell
I dont agree with that, but thats ok. We dont have to agree. I have had plenty of carbd cars that start up easy too, all of them in fact. But fuel injection does play a part in the quick starts, especially in cold weather, of newer cars. And more particularly, of newer cars, the ignition.
yep..here in MI its bitterly cold in the winters...when my car was TPI id bump the starter and it fire right and idle like it was 80 degrees...with my carb it needs a little more "attention"...but on warm days a simple pump on the gas pedal and it fires right up like the FI did
Engine: LT1, L400
I guess I should have prefaced my opinion with: I was talking about how a carbed engine started WARM. Obviously, setting the choke and getting the proper pump shot, and then drawing that through the intake takes more time than a MPFI engine, which does all that automatically. But once warm, a well tuned carb will start as quick as anything.
-Tom
-Tom
It is a combination of things. The injectors putting fuel right at the intake valves, doesn't have to travel through the carb and manifold, the "right" amount of fuel added for start up, higher compression than the 70's carbed cars, good ignition system and strong starters.
Car: 88 Camaro
Engine: L98 350
Had three TPI engines, none started up without several revs. First one had the cold start injector, still a long crank time. Figure a port injected engine should start quick. Had a Cutlass with the DOHC that started too quick, hear some lifter noise for a few seconds. Had to remember to hit the starter quick before fuel pressure came up to get a couple revs on the oil pump. Wish my TPI engines would start like that.
I've played with the 89 code (ARAP) in prom burning and GM had made it so it took a good 5+ seconds of cranking to get it to start. By changing a couple of parameters it will now start in 2 seconds or less.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Originally posted by Morley
There is no reason why they can't and unless they are 89's they should. My 85 would start right up with a flick of the ignition switch, even in the bitter cold of a N.D winter...without a block heater.
Originally posted by DuronClocker
What exactly did you change?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The_Phoenix
Sep 3, 2015 10:56 PM
db057
Aug 11, 2015 10:11 PM
