idling issues w/ thermostat replacement
Old Nov 2, 2004 | 10:50 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
I took out my old thermostat due to overheating,
i took off the throttle body assembly, and put it to the side w/ the throttle cable attached, then got the bolt off, n put on the new thermostat, replaced all the hoses etc.
Start the car up..... it idles at 3000 rpm now... kinda funky, i dont even have to push the gas anymore, total pain in the *** to drive....
anyone have an idea whats up w/ the car?
Old Nov 3, 2004 | 03:18 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
when it idles high, can you push the throttle back and make the idle drop, or is the throttle all the way back on the idle adjustment screw. if you cant push it back to normal idle, the iac valve might be unpluged, or vacume leak.
Old Nov 3, 2004 | 07:33 AM
robvas's Avatar
check for vacuum leaks, reset your base idle and make sure your TPS is set correctly. Also, make sure all the electrical connectors are plugged in
Old Nov 3, 2004 | 10:51 AM
91RSHawaii's Avatar
how do i reset the base idle... yes im pretty much new to this stuff
Old Nov 3, 2004 | 10:03 PM
QuickStyle's Avatar
Car: 91 Z28
check the main page for the "Tech Articles" alot of valuable information in there, the one you want to look under is the tps and iac adjustment
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Jlanz55
Sep 29, 2015 08:55 AM
